BUG/Enhancement
Description
| 249535 | [Page Format Designer] Fail to list page format for the restored project |
| 253222 | Workbook Set is Locked error in PLC Generator |
| 258614 | [PLC Generator]The software crash when executing the generate feature. |
| 278721 | [Graphical Parts List] An error message occurs when moving graphical parts list table |
| 289215 | When symbol Attribute display is made hidden it gets changed to visible |
| 307715 | Symbol Mirror I Mirrored Symbol which are placed when Mirroring is removed all the hidden Symbol Text are turned visible |
| 307821 | Lock Project I Lock project allows other user to delete, move, copy delete wire tag in read only page |
| 311007 | Insert Symbol I User is not able to place Wiring Diagram Symbol by using Insert Symbol by ID |
| 312771 | Wire Tag deleted while using Smart Move when Wire Crossing Preference is set to Loop Over |
| 313916 | [PW Explorer Plug in] An error occurs when opening a page from PW Explorer |
| 313920 | [PW Explorer Plug in] An error occurs when deleting a page from PW Explorer |
| 315856 | PLC Generator: When generating PLC diagram it is generated starting from current open page and not from Start in page no. |
| 315958 | Command Protection: User with Viewer role is able to delete the symbol using Microstation delete function |
| 325094 | [PW Integration] After delete a project, creating page in the new project will occur an error |
| 331290 | [Martian] It should be labeled with the translation character for Create WorkSpace and Create WorkSet |
| 334436 | Catalog Manager I Preview for users custom Macro & Symbol cannot be seen in catalog Manager or respective insert dialogs |
| 336710 | Insert Macro: When placing a Macro which includes a Field,symbol gets deleted and Object refernce error message pops up |
| 358186 | Updating Promis.e CONNECT overwrites the WorkSpace and WorkSet files |
| 362099 | PLC Generator: Issue creating new pages while generating PLC diagram |
| 362112 | Export to DWG: When page exported to DWG some insertion Points are still visiable as they are on default level |
| 365022 | Substation: Software Crash when create page macro |
| 367499 | Symbol text with "^" for next line have issue with visibility toggle in symbol text option |
| 372681 | URL from Part Number cannot be opened into Webbrowser by right click on symbol. |
| 372742 | Replace Family command creates duplicate families with different sub id for the parent and child symbols |
| 381440 | Wire Label: Wire label offset on vertical wire not same as horizontal wire |
| 394614 | [Wire Link] Wire link tag should not be displayed after rotate wire link |
| 394615 | [Wire link] It should add the right click menu command "Symbol Settings" for the Wire link symbol |
| 415328 | Wiring Manager: when a project is from Promis.e V8i is restored in Promis.e CONNECT the Wiring sequence in Wiring Manager is not maintained |
| 431630 | Catalog Manager I When Catalog is impoted in Catalog Manager it cannot be seen in Catalog Manager after restarting Promis.e again |
| 435592 | [Catalog Manager] The crash dialog pops up when close the product when Catalog Manager is opened in Dock |
| 437567 | Cross Reference I cross reference symbol details not reflecting correctly when family is assigned while inserting symbol |
| 336936 | [Run Reports]The BOM Number and Revision Number from the Symbol attributes not listed in the filter list. |
| 337084 | [Load Data by BOM Document]Rename revision and BOM Document number is not correct. |
| 337520 | [Load Data by BOM Document]Remove revision and BOM Document number, the tree view should be refreshed automatically. |
| 347124 | [Project Manager][ProjectWise Integration] Project Manager doesn't not show checked out icon after user closes page without checking in page |
| 347130 | [Navigate][ProjectWise Integration] navigate function automatically checks in file when user selects close at PW Check in prompt |
| 354590 | [Work Order Manager]The Work Order sort order is not correct if the work order name are numbers. |
| 358389 | [BOM Manager]The work order sort order is not correct if they all numbers. |
| 358807 | [Project Manager-Multiple database] It will close the page of the active project if users just click another project |
| 358883 | [BOM Manager]After edit several parts, the select all toggle cannot select all |
| 379908 | [PW-Project Manager] Project Manager Tree should default to ACTIVE Project and shows the ACTIVE Projects Page list under the Subfolder |
| 382558 | [Balloon Restore Project]Restore a project with balloon from BOM Manager, change the balloon number in the properties dialog, the balloon number will not change in the drawing. |
| 382570 | [BOM Manager-Requirement Date]It cannot assign Requirement Date to the BOM part that has been placed on the drawing in BOM Manager |
| 393308 | [DataManager][Pending] It always prompts the pending page when changing the Device ID in the Data Manger in the project |
| 393860 | [BOM Manager][Nameplates] missing symbol text in BOM Manager after user moves Nameplate devices to another BOM Manager Tree Node. |
| 406299 | Socket error when attempting to run multiple sessions of application on same machine |
| 410872 | [BOM Manager][Submit] and [Validate] Unhandled Error "Input string was not in a correct format" |
| 411479 | [BOM Manager] Unhandled Error when user changes Group By to Balloon after setting balloon number values using Group by Device |
| 431645 | [Configuration Variables] The catalog only defined under WorkSet and imported catalog is not displayed in Catalog Manager |
| 368900 | [PW_Create Electrical Project/Page] There is no response when click Create Electrical Project command on PW Explorer side |
| 394625 | [Symbol Settings] Mirror symbols in the default sample projects are wrong |
| 358364 | [Wiring][Multi-wire] Cannot place Multi-wire. |
| 384062 | [BOM Manager]The Insert Balloon button should not be useful when no device is selected in the BOM Manager dialog. |
| 369990 | [BOM Manager]Load data by BOM Document, click the Submit BOM, it always popups “There is nothing to submit”. |
| 366736 | [BOM Manager]Sometimes edit several parts together to an work order, the parts are not in the same work order. |
| 292414 | [Run Graphical Plan]It can only display one part number in the output graphical plan drawing. |
| 417539 | [PW_NetworkDriveCatalogs] Error appears while click Insert Symbol By Name after rename PW Managed WorkSpace Catalogs folder |
| 310660 | [Configuration Variables_PW] Set ELEC_SHOW_PWCHECKIN_DIALOG = False, the Check in dialog still pops up |
| 314732 | [BOM Explorer]Add attributes for a symbol in BOM Explorer, the attributes name display is not correct after reopen the BOM attributes dialog. |
| 429220 | [Balloon][Bacup Restore]Create a project with construction drawing, and reference 3d views, place balloon by BOM Manager in the drawing, backup, then restore, the balloon is missing. |
| 404794 | [Backup Restore]Backup a project, and then restore it, the symbol right click menu is lost. |
| 230802 | [Symbol Creation Wizard] Array option places attributes at incorrect x and y coordinates |
| 383012 | [Create Macro]Open the special page in the user’s project, and create macro, it popups error dialog. |
| 381905 | [BOM Manager Balloon]The balloon number is not correct if inserting balloon after modifying the balloon number. |
| 362302 | [Command Protection] Turn OFF Draw Wires,try to place Multi-polywire,there‘re still some segments placed in drawing |
| 231087 | [PW Cloud] Remove unnecessary CopyOut() functions from the source code |
| 419274 | [PW-Create Page] Create page will report error with PW project |
| 391659 | [Performance] improve open/close dgn performance |
| 386354 | [Create 3D Macro] Creating 3D macro will crash to the desktop with projects |
| 385665 | [SQL parts database]An error will pop up if you don't have SQL sa password. |
| 384815 | [BOM Manager] [Address fields] Unhandled exception occurs when entering single quotation marks (’) in address fields 1-7 |
| 365022 | Software Crash when create page macro |
| 313915 | [PW Explorer Plug in] Cannot update project properties immediately from PW Explorer |
| 287918 | [Place Labels-Report] It cannot generate the correct partnumber quantity with the SubID symbols in Place labels report |
| 385608 | [Balloons] Add new Engineering Design Consideration for Orphaned Balloons |
| 385632 | [Balloons] Add New Tool to Locate Orphaned Balloons on active page |
| 385636 | [Balloons] Add new tool to remove all unused Balloon Named Groups within active page |
| 385641 | [Balloons] Add new Tool to remove all Orphaned Balloon records from SymbolBalloonGroup table for active Project |
| 391827 | [AutoBackup] Support autobackup function in the environment with multiple databases |
| 283637 | [Balloons] Enhancing Balloon editing and updating functionality (Updates shouldn't change custom arrangement) |
