Product(s): | OpenUtilities Substation CONNECT | ||
Version(s): | 10.00.XX.XX to 23.00.XX.XX | ||
Environment: | N/A | ||
Area: | Installation_Configuration | ||
Subarea: |
The OpenUtilities Substation Program Data / Configuration folder contains "content", such as catalogs, parts databases, templates, and projects, along with various options profiles and settings. This folder is specified during installation but can be copied or moved afterward. The Configuration Variables can be used to find the location of the Program Data folder if custom location is used.
OpenUtilities Substation Update1 to Update 15
C:\ProgramData\Bentley\OpenUtilities Substation CONNECT Edition
C:\ProgramData\Bentley\OpenUtilities Substation 2023
Original Author: | Satish Saptasagar |
