| 435433 | [PW integration][Project Manager]Check in dialog pops up twice |
| 350224 | [Command Protection] The default checked ON Role's Right settings for the 4 default roles is not correct |
| 317970 | [Place 3D Macro] The icon should be updated to the new one in the Assign Device Tags dialog |
| 291181 | [BOM Manager]One balloon number is blank, it always popup unexpected information dialog if user set another balloon blank. |
| 365182 | [BOM Manager] Insert Symbol by Device ID->insert the symbol from BOM Manager, the inserted symbol does not have the BOM, work order and Revision number values. |
| 297890 | [Configuration Variables] Error appears when launch Substation with some not correct values for partsDB mapping, multi language mdb, system options, project options |
| 382451 | [BOM Manager-Requirement Date]It cannot refresh the Requirment Date when change the view from Material to Nameplate |
| 432681 | [ProjectWise Integration][Project Manager]Page status has not been updated after create next new page and new project |
| 432530 | [BOM Manager][Add Part][Custom Part] Auto-generated NC part number is not unique and/or is not numerical |
| 432708 | [BOM Manager]The balloons of the virtual devices are deleted in the construction drawing which reference a 3D page after clicking Remove button in the BOM Manager dialog. |
| 433471 | [BOM Manager]Remove a part number from a device in the BOM manager dialog, the work order/BOM/revision are changed to Unassigned. |
| 432585 | [Balloon][Backup Restore]Backup a project with invalid balloon groups are removed, and restore it, unexpected records are added to the [dbo].[SymbolBalloonGroup]. |
| 434611 | [Documentation]The help button link is not correct in the Edit Revision Properties dialog. |
| 435722 | [BOM Manager]Insert symbol by Device ID to insert a symbol with work order and BOM and revision in the drawing, the BOM and Revision attributes are lost. |
| 436220 | [BOM Manager]PGE ENV, Insert a symbol in the drawing, and assign the device tag with work order/BOM/Revision number defined in the BOM Manager, the work order of the symbol is changed to unassigned item. |
| 282611 | [PG&EProject][CopyProject] An error message occurs when copy the PGE project PIT #1 PH.Prj |
| 431310 | [BOM Manager][Data Grid] Balloon field should be default sort for data grid items |
| 431247 | [BOM Manager][Edit][Starting Balloon Number] Auto-assigned Balloon Number shall be unique per Nameplate device when SystemOptions setting Unique Balloons per device is enabled |
| 444905 | [ProjectWise][Explorer Promise/Substation Customization] unable to copy, delete, and move non-Substation/Promis.e design files using ProjectWise Explorer |
| 387268 | [PW_WithCatalogsOnlyOnNetworkDrive] It prompts " The physical file "" does not exist in catalog directory " when insert symbol by name after create a new catalog and create a symbol under it |
| 430588 | [BOM Manager][Submit] when mapped delivery address field for item has value (Not Null) use BOM Item Level delivery address else use address from BOM Revision Properties |
| 367863 | [BOM Manager]It can rename the revision the first time when there is a device placed in the drawing, but cannot rename the second time. And a duplicate revision name is created. |
| 444644 | [Insert Macro]It popups error dialog when inserting a macro in the page. |
| 433181 | [BOM Manager][Submit] incorrect submission flag status |
| 433170 | [BOM Manager][Submit] handle unknown responses from response JSON |
| 433407 | [Balloon] Remove all part numbers from the Device properties dialog, the balloon number of the related part number and the leader should be deleted from the drawing. |
| 432984 | [Balloon] Delete one of the circles of the balloon by delete key or delete Element, the whole balloon are all deleted from the drawing. |
| 385755 | [Balloon]It popups error dialog when placing the second balloon for the same symbol in a construction page. |
| 432522 | [Device][Cross-Reference][Display] Child and Duplicate Cross References appear regardless of Project Options settings |
| 431961 | [ATP] [Ribbon Hotkey] Removed Orphaned Balloons and Insert Symbol By Device ID have duplicated hotkey “OR”. |
| 444279 | [Utilities][Auto Backup] add "Include Subfolders" option for each source path |
| 438465 | [BOM Manager][Submit] Display SAP error message in BOM Manager Submit dialog |
| 431244 | [BOM Manager][Nameplate] Add SystemOptions setting - Unique Balloon Number Per Nameplate Device |
| 447708 | [BOM Manager]Switch between Nameplate and Material, the records cannot display in the grid when Work Order/BOM/Revision are all Unassigned. |
| 435222 | [Update Family]Only insert a parent symbol in the drawing, and update family, it popups error dialog. |
| 445908 | [Project Options][Standards][Text Settings] hidden symbol text attributes become visible after enabling "Scale text by page scale" option |
| 391989 | [PW_WithCatalogsOnlyOnNetworkDrive] An error appears when click the Title Block browse button in the New Page dialog |
| 381857 | [BOM Manager] The Requirement Date's data type should be the DateTime in the BOM Manager |
| 431321 | [BOM Manager][Data Grid][User Defined Sort] retain user defined sort settings, for Group by Device and/or Group By Balloon views |
| 445967 | [ProjectWise][Project Manager] Project Database Connection not reset to Project Database for active (open) page |
| 451119 | [BOM Manager]It should be sorted order correctly by Device in BOM Manager |
| 368765 | [Multi-DB performance]Slowdown was noticed on the actual Restore of the Oakland D project. |
| 334436 | Catalog Manager I Preview for users custom Macro & Symbol cannot be seen in catalog Manager or respective insert dialogs |
| 415328 | Wiring Manager: when a project is from Promis.e V8i is restored in Promis.e CONNECT the Wiring sequence in Wiring Manager is not maintained |
| 437782 | [iModelHub]The software will crash to the desktop when I publish a project to the server in Promis.e 10.06.00.39. |
| 431630 | Catalog Manager I When Catalog is impoted in Catalog Manager it cannot be seen in Catalog Manager after restarting Promis.e again |
| 439985 | [Project Manager] Promis.e will close directly when we launch it and left click to select a page or click Thumbnails in Project Manager |
| 435592 | [Catalog Manager] The crash dialog pops up when close the product when Catalog Manager is opened in Dock |
| 362099 | PLC Generator: Issue creating new pages while generating PLC diagram |
| 433205 | [Project API Builder] it prompts pending changes when generating new Project using user's WorkSpace |
| 325094 | [PW Integration] After delete a project, creating page in the new project will occur an error |
| 442343 | [BOM Manager] It reports error when I right click the right panel blank area. |
| 438594 | [Wiring Manager] The location/ordering of these devices is incorrect when connected with the Diagonal symbol in the Wiring Manager |
| 437567 | Cross Reference I cross reference symbol details not reflecting correctly when family is assigned while inserting symbol |
| 443148 | [Insert Macro]Insert a macro with diagonal, it popups error dialog. |
| 365022 | Substation: Software Crash when create page macro |
| 441626 | [Diagonal wire] Deleting one modification diagonal wire will not generate wire node connection |
| 446095 | [Wiring Manager] The location of some devices is incorrect in the Wiring Manager in the Solar Workspace |
| 445193 | [PLC Generator] The terminal number is always displayed as a question mark on the drawing and the suppression id does not work after run PLC generator |
| 448713 | [ProjectWise Explorer Plug in] An error occurs when deleting a project from ProjectWise Explorer |
