| 473609 | [BOM Manager] add capability to allow user to reserve balloon numbers (add spares) |
| 502039 | [BOM Manager][Nameplate] improve message when user renumbers nameplate balloons if balloon is already associated to a different item on same BOM Document Number |
| 502058 | [BOM Manager][Nameplate] allow user to renumber balloon if duplicate balloons are part of selection set being renumbered |
| 230870 | Cable trench are extending beyond given point |
| 236241 | Cut behaves like Extend for Repeating part types |
| 440121 | Move Command: Changes the level of Cable attached to the Hook Equipment when using Hooked Objects in Move |
| 456561 | [Performance] [Insert Symbol] Improved performance during repetitive symbol placement |
| 460138 | [Insert Substation Objects][Placement Options][Cable Method] symbol does not properly follow contour of cable bus object is user applies rotation value in Angle field |
| 460139 | [Move][Cable Method] symbol does not follow contour of cable/bus and unable to define new position properly |
| 460164 | [Dimensions Style]Add two Dimensions Style in Dimensions Style dialog, and do not activate it, and restart the software, the two added style cannot be activated. |
| 462892 | [Stretch][Variable Object][Cable/Bus] Quantity not updated after user uses Stretch command |
| 473174 | Insert Cable: 3D Cables inserted in 3D layout mode with the Millimeters as units the cable is not inserted correctly |
| 473379 | [BOM Manager][Edit][Starting Balloon No] incorrect handling of balloon number assignment for devices without partnumbers |
| 473623 | [BOM Manager] change device's partnumber for device with placed symbol removes part number and balloon values from device associated with placed symbol |
| 473627 | [BOM Manager][Validation][Duplicate balloon number] not always showing all duplicates |
| 476000 | [Delete][Field]Installation and Location values not updating after user selects Yes to rename Installation/Location fields |
| 476003 | [Delete][Field] Installation, Location, and Device Tag values disappear from Device Properties after user selects No to not duplicate device ID's |
| 476703 | [Device Properties][Select Device ID] unexpected Device usage chart appears after selecting device ID on drawing |
| 478191 | [BOM Manager][Submit] Submit Flag not set when BOM is submitted to SAP |
| 479016 | [BOM Manager][Edit][Starting Balloon No] unable to renumber Nameplate balloon number if Starting Balloon number less than or equal to highest balloon in project |
| 479963 | [BOM Manager][Submit] field or fields not truncated properly |
| 482210 | [Move To Database] incorrect message displayed when one or more pages of project are open |
| 483586 | [Reports][BOM_Substation_QTY] missing report records when filtering by WorkOrder, BOM Document, Revision Number |
| 488605 | [Performance] Insert Symbol dialog |
| 488721 | [Display Style] Setting the Display style will crash |
| 499586 | [BOM Manager] work order attribute missing when user places symbol for device in BOM Manager |
| 506556 | [Copy Project][Work Order Manager] Work Order Manager will list duplicate work order in the copied project |
