Product(s): | Promis.e CONNECT Edition | ||
Version(s): | 10.00.XX.XX to 10.06.XX.XX | ||
Environment: | NA | ||
Area: | Platform Support | ||
Subarea: | NA |
Right Click in Promis.e is used by user as Reset Button and when help pressed for longer time it can be used to access Secondary Menu / Right Click Pop up Menu. But users may some time face issue when they press Right Click for Reset and when help longer it will Pop up the Secondary Menu or Vice versa.
In this Wiki Article we will go through the details on how to change the delay time for Right Click Pop up Menu.
1. In Promis.e CONNECT go to Promis.e Project Manager and select Settings >> User >> Preferences.
2. In the Preference dialog select Input under Category, now for the Option Hold Delay increase or decrease the time according to requirement. If you want to delay the response time increase the time by making the delay Long, else decrease the delay making the response time short and select Ok to save the settings.
Original Author: | Satish Saptasagar |
