| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX | ||
| Environment: | Windows 7 64 bit | ||
| Area: | - | ||
| Subarea: | - | ||
| Original Author: | Rahul Kumar, Bentley Technical Support Group | ||
While launching OpenPlant Modeler, Line 241 error text window prompts which does not allow user to move ahead and modeler needs to close OpenPlant Modeler.
Modeler receives an Error: Line 241 while opening OpenPlant modeler. See Error message and image for references.
Error Message in Text window:
Exiting, C:\ProgramData\Bentley\OpenPlantModeler V8i\ WorkSpace \User\OPmodeler.ucf not found, [C:\Program Files (x86)\Bentley\ OpenPlantModeler V8i\OpenPlantModeler\config\msconfig.cfg], line 241
While defining a new path, it has been required to define the path in msdir.cg file present inside OpenPlant Modeler executable folder. See below image and steps to fix this issue.
See path where workspace has been stored:
C:\ProgramData\Bentley\OpenPlantModeler V8i\Workspace123\WorkSpace
Check path inside MSdir.cfg file: This can be found under below mentioned path.C:\Program Files (x86)\Bentley\OpenPlantModeler V8i\OpenPlantModeler\config
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU!
