| Product(s): | ProSteel | ||
| Area: | Drawing Production | ||
| Subarea: | Detail Center | ||
In the drawings generated from the Detail Center, the Description text is by default placed on the bottom left of the drawing.
1. Open the Detail Center Standard and under the parts tab, right-click on the required Detail Style used then edit the style.
2. In the Detail Style dialog, expand the ‘Descriptions’ tab and click on the additional text.
3. Here at the bottom, expand the ‘Alignment’ option and choose the alignment as ‘Middle’
4. Save the Detail Style and regenerate the drawing. This will shift the drawing description to the center of it.
