| Product(s): | ProSteel | ||
| Area: | Detail Center Standard | ||
| Subarea: | Detail Style | ||
In this wiki, we will learn how enable the display of Weld flags in the drawing. Follow the steps below which are necessary changes needed to be made in the Detail Style.
1. Under the steel workflow, navigate to the Detail Center Standard located under the Drawing Production tab.
2. Select the Detail Style and right-click to edit the required detail style.
3. First make sure that the weld flags settings are enabled which can be checked under Default Settings>Common.
4. Now, go to Descriptions>Weld Symbols, and Enable the options for the display of Weld flags and group and end plates under the General section.
5. After turning on these options, refresh the preview and you will be able to see the weld symbols in the drawing.
