| Product(s): | ProSteel | ||
| Area: | Drawing Production | ||
| Subarea: | Detail Style | ||
The position flags displayed in the drawing have specific alignment and this requirement differs from user to user. In this wiki, we will learn how to change or control the alignment of position flag in the drawing from the settings of Detail Style .
Follow the Steps below:
1. Under the Steel workflow, navigate to the Drawing production>Detailing>Detail Center Standard.
2. Right click on the Detail Style which needs to be edited and click on the ‘Edit style’
3. Now, expand the Descriptions tab and click on the Position Flags. Here, Under the ‘Alignment’ option, you can set the alignment of the Position flag as per the need.
4. Once the desired setting is applied update the drawing and preview the result.
In this way, position flags in drawing can be aligned with this change in the Detail Style setting.
