| Product(s): | OpenUtilities Substation CONNECT Edition | ||
| Version(s): | 10.00.XX.XX to 10.09.XX.XX | ||
| Environment: | NA | ||
| Area: | Component Feature | ||
| Subarea: | NA |
Many times users close / remove any Pane in Insert Symbol or Macro dialog they are not able to get the Pane back like eg. Preview, Catalog Tree Pane. This Wiki Article helps in resetting the dialog so that users are able to see the missing pane.
1. In the Insert Symbol / Macro dialog that is affected select the down arrow which is located to the left of Place Symbol button and select Resetb Layout.
2. Select Yes in the Confirm Reset dialog.
| Original Author: | Satish Saptasagar |
