| Product(s): | ProSteel | ||
| Area: | Drawing Production | ||
| Subarea: | Detail Center Standard | ||
In the Detail Styles, by default the option foe showing the diameter values of holes in end plates is turned off so, the users can’t see this value in the drawing.
In this wiki, we will learn how to enable this option.
1. Under the steel workflow, navigate to the Detail Center standard located under Steel>Drawing Production>Detail Center Standard.
2. Now, in the dialog, right-click on the required Detail Style and select ‘Edit Style’.
3. Now, expand the ‘dimensioning’ options, click on the common>holes, and under the “holes in top view’ section, enable the option ‘Also in end plates’.
4. Now, update the preview and you will be able to see the diameter of the holes displayed in the drawing.
