| Product(s): | ProSteel | ||
| Area: | Detail Style | ||
| Subarea: | Dimensioning tab - Detail Style | ||
| Original Author: | Kemuel Jancorda, User Success Team |
This wiki will guide you on how to disable outer edge dimensions in a View 2D drawing so that you can only display and highlight View dimensions between Grid lines/Axis.
Open the Detail Style dialog, go to Dimensioning > Views, and here under the General section, uncheck the option Outer Edge Steel. If a certain steel plate needs to be filtered out, you may retain this option and apply the Filter for Outside Edge Steel options around.
