| Product(s): | ProSteel | ||
| Area: | Detail Style | ||
| Subarea: | Dimensioning tab | ||
This wiki will show how one can group or ungroup the same dimensions in the 2D drawing using Detail Style options.
Group the Same Dimensions:
1. Preview your drawing in the Detail Center and open the Detail Style.
2. Go to Dimensioning > Common > Optimization and check the Same Dimensions option to group all same dimension together and then Update the preview.
The results will be as shown in the below image.
Ungroup the Same Dimensions:
2. Go to Dimensioning > Common > Optimization and uncheck the Same Dimensions option to ungroup all same dimension and then Update the preview.
In this way, one can group or ungroup the same dimension in the 2D drawing.
