| Product(s): | ProSteel | ||
| Area: | Detail Center & Drawing Production | ||
| Subarea: | Dimensioning - Detail Style | ||
In the below image, we can see the arrows for the dimensions.
This wiki explains how one can get the architecture tick mark in the 2D drawing for the dimensions via the detail center.
1. Open Dimension Styles dialog from the Search Ribbon.
2. Copy the required dimension style and under the Geometry tab, left click on Symbols and set options as below. Then save the style and close the dialog.
Arrow: Cell | Name: _Oblique
Dot: Cell | Name: _LeaderArrow
3. Now, open Detail Center, preview the drawing and open Edit Detail Style. Go to Dimensioning > Common and select the newly created dimension in Dimension Style Normal section.
4. Update the preview to see the changes.
In this way, one can set the tick mark for the dimensions in 2D drawing.
