| Product(s): | ProSteel | ||
| Area: | Detail Style | ||
| Subarea: | Dimensioning tab - Detail Style | ||
This wiki will guide you on how to set the coordinate dimension so that the dimension value will come near to the object.
Open the Detail Style dialog, go to Dimensioning > Common, and here select the Coordinate Dimension as Dimension Line Rotated and uncheck the option Coord Dimension Extra then your results will be as shown in the below image.
Please take note that one must activate the coordinate dimensions in their respective drawings and direction. This can either from origin of detail or model. Refer to the image below.
