Removing Spec Break Symbol in Isometric Drawing-v8i
 Product(s): OpenPlant Isometrics Manager
 Version(s):Up to 08.11.09.404
 Environment: Windows 7 64 bit & Others
 Area: Settings/Attributes
 Subarea:
 Original Author:Rahul Kumar, Bentley Technical Support Group
Requisition has been made by some user to remove the spec break from Isometrics Manager as per their requirement. Below is the customization done to achieve the desired workflow. However this can be considered as an alternative workaround by removing the symbols from library and is beneficial for the user's who are using the version stated above in template.
To remove a spec break option, it is needed to define the new spec break in second available ‘custom.cel’.
  1. Launch Open Plant Isometrics Manager, and open configuration dialog box.
  2. From Advance node option, open seed file.
  3. Go to iso extractor and click on cell creation tool.
  4. Navigate to cell template folder and select Annotation to open.
  5. Copy the spec break label and paste it to down below. Delete the spec break label and leave a point there. See image below:
  6. Place a fence and click to create cell option.
  7. Select the Cell Library and provide cell name and description to it.
  8. Save the changes and verify the order of custom.cel written in style.cg file. See notes below
    Notes:
    a. If a template file as shown in point no 4 does not appears, copy the OPIM folder from below mentioned path to your workspace.
           C:\ProgramData\Bentley\OpenPlantIsometricsManager V8i\WorkSpace
    b. User may create its own custom file with logical name and customize the label accordingly. To enable a new cell file type the name at first place in style.cfg in order to search the library at first, as mentioned in below image.
communities.bentley.com/.../12647.modifying-symbols
Comments or Corrections?
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU!
