Managing Spec Breaks on Isometrics Drawing-v8i
 Product(s): OpenPlant Isometrics Manager
 Version(s): 08.11.09.440 & Above
 Environment: Windows 7 64 bit & Others
 Area: Settings/Attributes
 Subarea:
 Original Author:Rahul Kumar, Bentley Technical Support Group
In OpenPlant Isometrics Manager, Spec Breaks appearances are in general discussion to show it up in isometrics drawings. Various requisition has been made to describe the change of spec in iso drawings based on project utilities and also based on different specs or to show few specs in particular. Below description highlights managing spec breaks with few use cases. To note, this has been added recently from the version mentioned in template above.
A. To Toggle off all Spec Breaks in OPIM
  1. Launch Open Plant Isometrics Manager, and open configuration dialog box.
  2. From Advanced node option, click on Explore style button.
  3. Go to Config folder and open Style.cfg file.
  4. Check Variable IE_ExcludeSpecBreak = *.
  5. Remove ‘#’ sign from it. This will Toggle off all Spec break from drawing.
B. To remove few Specs in an isometric Drawing.
  1. Repeat Step 1 to 4 shown above.
  2. Remove ‘#’ sign from file and type spec name which is not required. Say mEX-OPM.
    Note  -  This will remove all spec breaks containing spec mEX-OPM.
Modifying Symbols
Bentley Communities
Applies To Product(s): OpenPlant Isometrics Manager Version(s): 08.11.09.XXX Environment: Windows 7 64 bit Area: Settings/Attributes Subarea: - Original Author: Keith...
 communities.bentley.com/.../22225.removing-spec-break-symbol-in-isometric-drawing
Comments or Corrections?
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU!
