How to change Gasket Size-v8i
 Product(s):OpenPLANT Isometric Manager
 Version(s):08.11.09.440
 Environment: Windows 7 64 bit
 Area: Customization
 Subarea:
 Original Author:Dinesh Solanki, Bentley Technical Support Group
Introduction
It is required by users to modify the size of the gasket according to requirement. This wiki explains how size of gasket is increased to show it in the isometrics. The steps below are in context to OpenPLANT Modeler with OpenPLANT Isometric manager however the steps remain the same when user is using AutoPLANT Modeler with OpenPLANT Isometric manager with some changes in the path.
1. Using Isometric configuration open seed file
2. Go to IsoExtractor--->Cell Creation Tool to Open Create Cell Dialog
3. Click Open Template file button to open Select Template file dialog. Browse to your project path to open Custom.cel
4. Now, import the (gasket) cell PGKT from lisocomp.cel to custom.cel using steps below.
5. Stretch the gasket using Microstation "Stretch" command.
6. Open symbolsizes.def file and change DEF B2CP    GASKET SEGLEN    1 . This file can be accessed using Isometric configuration.
7. Generate the Isometrics to get the required gasket size.
For similar customization on cell template in details check below links:
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/12647.modifying-symbols
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/20274.how-to-not-show-gaskets-in-isometrics/edit
Comments or Corrections?
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU!
