| Product(s): | ProSteel |
| Version(s): | All |
| Area: | ProSteel Global Settings/Options |
| Subarea: | Plates tab |
| Original Author | Steffen Knoll, Bentley Technical Support Group |
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
If value of the width is higher than of the length the name should still show the shorter value of the length first.
Option Length is always largest value is turned on.
Please follow the below steps to resolve this.
1. Open the Global Settings or Options by holding the right mouse button in the View window and then click on the Options.
2. Go to Plates > Plate Description and switch off the option Length always the largest value.
Now, you will get the shorter value length first in the name as defined in the Name Description syntax.
