How To Change The Dimension Color in Isometrics Drawing- v8i
Product(s):OpenPlant Isometrics Manager
Version(s):08.11.09.404 & above
Environment:Windows 7 64 bit & Others
Area:Settings/Attributes
Subarea:-
Original Author:Rahul Kumar, Bentley Technical Support Group
To change dimension color on line in OpenPlant Isometrics Manager.
During Isometrics drawing generation process,both OpenPlant Modeler/AutoPlant Modeler, dimensions color can be changed based on project requirement and color coding pattern used differently. Below steps illustrates changing the color for dimensions in Isometrics drawing.
  1. Launch OpenPlant Isometrics Manager. Select Project unit.
  2. Click on ‘Configuration’ tool. See image below.
  3. Under ‘Isometric Style’ tab, go to ‘Advanced’, then ’Open Seed File’. See image below.
  4. Open Seed File.
  5. From ‘Element’, Select ’Dimension Styles. See image below.
  6. Under ‘Symbology’ tab,Change the Text color to desired one. See image below.
  7. Close the dialog box.
  8. Go to Files ->Save settings ( CTRL+F). See image below:
  9. Generate Isometrics. Color will get changed. See image below:
communities.bentley.com/.../12639.modifying-dimension-styles
Comments or Corrections?
