How To Change The Dimensioning Style To Use Dimension With Leader Line- v8i
Product(s):OpenPlant Isometrics Manager
Version(s):08.11.09.404 & above
Environment:Windows 7 64 bit & Others
Area:Settings/Attributes
Subarea:-
Original Author:Rahul Kumar, Bentley Technical Support Group
To add a leader line in OpenPlant Isometrics Manager.
During Isometrics drawing generation process through both OpenPlant Modeler/AutoPlant Modeler, dimensions are placed on top of line, which has been set be default by OpenPlant Isometrics Manager. To facilitate Leader line for dimensions below steps are required.
  1. Open the seed file
  2. From the MicroStation menu bar select: Element > Dimension Styles.
  3. Select the Geometry tab.
  4. Change the Dimension with Leader section to as shown below.
  5. Give a Save Settings command (CTRL+F).
  6. Verify result. In case there is not enough space to place the dimension value between the dimension end points, MicroStation will place the dimension value at a distance from the dimension line.
    Note- MicroStation “Modify Element” tool can modify every part of the dimension.Moving the text and dimension line are the most common uses. See below.
communities.bentley.com/.../12639.modifying-dimension-styles
Comments or Corrections?
