| Area: | ProSteel Options | ||
| Subarea: | Shapes tab | ||
| Original Author: | Roger Belen, Bentley Technical Support Group | ||
| Updated By: | Vyanktesh Nama, Bentley Product Advantage Group |
ECS Axes : The Entity Coordinate System is displayed. It mainly serves for verifying purposes. Knowing how to turn this on and off and setting this in ProSteel/ProStructures options.
This Option can be set globally in the ProSteel/ProStructures options.
Note: ProSteel/ProStructures options dialog contains the default settings data, or global setting information, for the model. Changes to this options will only be applied to newly created objects the existing ones needs to be change manually.
At insertion, the shapes obtain the settings that were set in the ProSteel/ProStructures Options. If this needs to be turn off from an existing elements it can be overwritten individually by going into the Element Properties Dialog Box.
