How To Modify Text and Bubble Color For Weld Labels-v8i
 Product(s): OpenPlant Isometrics Manager
 Version(s):08.11.09.404 & above
 Environment: Windows 7 64 bit & Others
 Area: Settings/Attributes
 Subarea:
 Original Author:Rahul Kumar, Bentley Technical Support Group
To modify Text and Bubble color for weld label in OpenPlant Isometrics drawing.
In OpenPlant Isometrics Manager, it has been required many times to change the color for weld bubbles and text. This can be done by modifying the cell templates. It can be experienced using both OpenPlant modeler and AutoPlant Modeler. This has been shown in context with OpenPlant Modeler and OpenPlant Isometrics Manager. However similar approach could be utilized for AutoPLANT modeler and OpenPlant Isometrics Manager, using the isometric Configuration dialog, either using in session from project administrator (Mentioned below) or from out session using start menu and launching OpenPlant Isometrics Manager.
  1. Launch OpenPlant Isometrics Manager.
  2. Select Project unit, say OPModeler_Metric here and click OK. See image below:
  3. Click on ‘Configuration’ Icon to launch Isometric configuration dialog box.
  4. From Isometric configuration dialog, select ‘Advanced’ node and click on ‘Open Seed File’ option to allow user to open seed file..
    Note: For AutoPLANT Modeler & OpenPlant Isometrics Manager, to open Isometric Configuration dialog, launch Project Administrator and browse working project  ->OpenPlant Isometrics->Settings->Create/Modify.See image below.
    For launching OUT-Session, click on icon and select Tools-> Configuration button on launch.
  5. From IsoExtractor menu, click on ‘Cell Creation Tool’. See image below.
  6. From Create cell dialog, click on ‘Open template File’.
  7. By default the cell template is stored under …\OpenPlant isometrics Manager \workspace\OPIM\Cell Templates folder. Select Annotation DGN file and click on ‘Open’. See image below.
    Note: It is a good practice to create a backup of the template file before making any modifications.
  8. Go to Weld table and copy the text and table rows by using right click context menu and paste it above to define it separately for assigning colors. See image below.
  9. Select text and edit and rename it to WELDID. See image below.
  10. Select bubble and click on element information icon  .
  11. Modify the circle and assign desired color, line weight etc. See image below.
  12. Similarly modify the Text by selecting line inside the circle and pressing element information icon.  .
  13. From Task bar, Place Fence using fence type as Block, and Fence mode as Inside and click on ‘Create Cell’ Option. See images below.
    Note: user need to define cell template using ‘Create Cell’ option to be able to use further.
  14. From ‘Create Cell’ option, defined cell Name as WELDID, and add description as shown in below image.
    Note: It is recommended to use ‘Custom.cel’ from cell library, as the changes will retain in one separate file and it will not alter standard cell file lisocomp.cel which will allow user to use the custom.cel file for other project by copying it from one project location to another. By default it does not contain any information. To create a new cell file, copy paste the custom.cel file and type the name at first place in style.cfg in order to search the library at first, as mentioned in below image.
  15. Click on OK and Exit Seed file.
  16. Generate Isometric Drawing and verify results. See images below.
    Default Weld labels:
    After Modification:
See Also communities.bentley.com/.../12647.modifying-symbols
Comments or Corrections?
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU!
