| Product(s): | ProSteel | ||
| Version(s): | V8i | ||
| Area: | Steel Placements | ||
| Subarea: | Plates | ||
| Original Author: | Steve Crabtree, Bentley Technical Support Group | ||
| Update By: | Vyanktesh Nama, Bentley Technical Support Group |
You can use the ProSteel Plates/Polyplates dialog box to change a standard steel plate to a Polyplate.
