| 500362 | [Promise Installation] SQL Express 2016 with the installation package |
| 336592 | Command Protection: user needs Create WorkSpace & Workset, Copy Project and Move to Database function to be part of Command Protection |
| 252394 | Part number text on two lines. |
| 334343 | [Command Protection] It should not allow to create new database in New Project,Copy Project and Restore Project through Project Database Utility when turn OFF Configure Databases |
| 445168 | [Component] Mirrored symbol attributes text coordinates need to be corrected |
| 473880 | [Copy Project] Copied Projects don't have Pending changes included |
| 444076 | [Diagonal wire] After replace the family, the diagonal wire connection command will be invalid |
| 474736 | [Diagonal Wire] When drawing diagonal wire type between to wire potential no EDC dialog pops up |
| 490881 | [Insert Macro] When a symbol attribute containing "(Inch Symbol) is used to create Macro, when the macro is inserted the Value " is changed |
| 526223 | [Installer] SQL Database connection issues occur when Microsoft SQL Server 2014 Express (BENTLEYECAD) option is deselected during installation |
| 517361 | [Multi Language MDB] Error: Could not use "; file already in use |
| 421954 | [Part Number] It cannot display the correct part number position with the modified part number |
| 420142 | [Part Number] It should add the Part Number right click menu for the top part number |
| 420158 | [Part Number] It will move the Part Number position without changing anything in the Text Setting dialog |
| 420573 | [Part Number] Multi part numbers cannot be dealt with properly in the Sample projects and old projects |
| 421706 | [Part Number] The rotated symbols cannot display the correct position of multi part number |
| 484335 | [Performance] Wiring Manger taking long time to open or not responding for database that has more then 2500 projects |
| 482958 | [PLC Generator] Issue with PLC Diagram creation for Project located on Network location |
| 443072 | [PW][Import Catalog]Connect with PW, import a catalog, the imported catalog cannot list in the catalog manager dialog in time after importing. |
| 459428 | [Regional Setting] The decimal symbol cannot keep dot after setting it. |
| 276493 | [RestoreProject] Cannot restore project by double-click a .Prj file of promise |
| 524263 | [Seed Files] Split seed files for each product (Substation and Promise) |
| 457100 | [Spare Terminal]: When adding Spare terminal for part number with decimal quantity the user gets Unhandled Error message |
| 532459 | [Symbol Text] editing multiline symbol text changes the attribute's original insertion point |
| 474786 | [Wire Link] When placing wire link pair on wires with different potential the user doesn't get EDC check dialog |
| 322029 | Command Protection: Restore Project from Tools option allows user to restore project even if there is command protection restriction for Restore |
| 384236 | Diagonal Wire Connection insertion point visible in export to DWG when the level is turned off |
| 366104 | Disabling of Selecting WorkSpace and WorkSet not working with Promis.e but works in Promis.e Microstation mode |
| 283215 | Display of page is not perviewed in Project manager if we scroll through keyboard |
| 444046 | Promise Connect:- Wire layer is not getting display after certain limits |
| 473770 | Symbol text appears on Parent child when value added to child symbol which contains ^ in value for symbol attribute which is hidden |
| 450416 | TLS 1.2: User cannot create Parts Database Path for parts database on SQL Server using only TLS 1.2 settings |
| 283645 | [Balloons] Place Balloons tool needs to work in construction drawings |
| 455771 | Substation Workflow configuration— Support fasten the customized workflow in the Menu bar |
| 473609 | [BOM Manager] add capability to allow user to reserve balloon numbers (add spares) |
| 482542 | [PW Integration]Add new column "CheckedOut By" in Project Manager and synchronize the documents status in Project Manager with ProjectWise Explorer |
| 499473 | Add the spare part out of the balloon range |
| 502039 | [BOM Manager][Nameplate] improve message when user renumbers nameplate balloons if balloon is already associated to a different item on same BOM Document Number |
| 502058 | [BOM Manager][Nameplate] allow user to renumber balloon if duplicate balloons are part of selection set being renumbered |
| 504143 | [BOM Manager][Wire Link ID's] exclude all wire links from BOM Manager data grid |
| 505125 | We should disable Insert Spare command when data is loaded using “By Work Order” option in BOM Manager dialog |
| 230870 | Bentley Substation : Cable trench are extending beyond given point |
| 231503 | [Insert Substation Objects]Insert Clamp with Cable method, it cannot work correctly if changing the Method in the Placement settings dialog. |
| 236241 | Cut behaves like Extend for Repeating part types |
| 312217 | [Martian] Some fields are translated and some are not translated in BOM Manager -> Customization |
| 312257 | [Martin]There is a duplicate “Material” in the drop down list, and the Show All is not translated. |
| 317970 | [Place 3D Macro] The icon should be updated to the new one in the Assign Device Tags dialog |
| 365752 | [BOM Manager]Sometimes it popups error dialog when clicking the browse button of the part number. |
| 381904 | [Balloon]The unselected balloon number is not changed if not selecting all the balloon numbers in the modify balloon dialog. |
| 382399 | [Reference]Active a reference page and deactive it, open the original page, it always popup unexpected dialog. |
| 387351 | [Submit to SAP] Unhandled exception occurs when submitted part does not belong to the active part database. |
| 392541 | [BOM Manager] It reports error when assign balloon no to the part item in the BOM Manager |
| 393300 | [BOM Manager][Report]Drag some data from Unassigned work order to an existed work order, the data cannot display in the report filter with the work order. |
| 432980 | [Balloon]Select all the balloons->right click Move, move the balloons, it change the balloon arranges and returns to the original. |
| 433408 | [Balloon] Delete the balloon number in the device properties dialog, the original balloon number still display in the drawing. |
| 434657 | [Documentation] The Mode Manager dialog in help file should be updated to new UI |
| 435223 | [Submit BOM] Unhandled exception occurs when submitting BOM in the customized project “PIT #1 PH.Prj”. |
| 438307 | Insert Cable / Bus : The command reverts to default Phase level after placement of each cable segment |
| 439904 | [Hook Point Manager] It cannot pick a blank point coordinate from the drawing in the Hook Point Manager |
| 440076 | [Project Manager]Error appears with modify page command in the Project Manager |
| 440121 | Move Command: Changes the level of Cable attached to the Hook Equipment when using Hooked Objects in Move |
| 440886 | [Balloon]Change the balloon number from “?” to an existed part number, the balloon in the drawing is not correct. |
| 442337 | [Martian][BOM Manager] Some texts in BOM Manager are not localized. |
| 444125 | [Project Manager][Page List] sort function not sorting records numerically or alphabetically for Ascending/Descending Sort functions |
| 446234 | [PW_Restore] Fail to restore project with data from Conduit Builder tool to managed PW |
| 449234 | [PW Integration] The page that opened from the PW Client side will be read only |
| 449245 | [PW Integration] Symbols cannot be found in the catalog when open the copied page |
| 449326 | [PW Integration] Click Title block field reports error in the New page dialog with the restored project |
| 452268 | [BOM Manager] It should maintain the sort order after switch Group by Balloon to Device |
| 452865 | [Insert Symbol][Recently Used] The user is not able to quickly switch between two different Recently Used symbols, Double Click selects incorrect symbol |
| 453726 | [BOM Manager]BOM Manager->group by Device->Add Device with toggle of Create separate device per part turn off, and select a part number with quantity=2, two devices are created. |
| 454192 | [BOM Manager] sort order not maintained when setting Group By to Device |
| 455195 | [PW_WithCatalogsOnlyOnNetworkDrive]Modify catalog order in Modify catalog path dialog then its order cannot retain when open it next time |
| 455418 | [Software Startup] Unhandled internal error on startup when invalid path format exists in Substation.cfg |
| 455432 | [Software Startup] Application is frozen when invalid path exists in Substation.cfg if you clicks Cancel in Configuration Variables dialog. |
| 457551 | [PW Integration][Project Manager] It will pop up check in dialog twice when close page in Project Manager |
| 459467 | [PW_NetworkCatalog] The defined network catalog is not available in Catalog Manager |
| 460046 | [Unhandled Error] Page Open error Type CDT.CdtCommandManager |
| 460059 | [Project Manager]Incorrect Tool Tip Message |
| 460066 | [Software Startup] Unhandled Error when DBSettings.xml is missing |
| 460072 | [Software Startup] Unhandled Errors when required files are missing from Datasets\Substation\Config folder |
| 460131 | [Software Startup] Unhandled internal error on startup when Substation.cfg is missing |
| 460133 | [Software Startup] Configuration Variables not showing variable values which exist in Substation.cfg when one or more variables are missing |
| 460136 | [Software Startup] Unhandled Error on startup when PartsDBMappings.xml is missing |
| 460138 | [Insert Substation Objects][Placement Options][Cable Method] symbol does not properly follow contour of cable bus object is user applies rotation value in Angle field |
| 460139 | [Move][Cable Method] symbol does not follow contour of cable/bus and unable to define new position properly |
| 460140 | [Move][Cable Method] symbol's existing rotation value is not maintained if symbol was rotated using Rotate Object command |
| 460143 | [Project Manager]Error occurs when project names with a suffix of space |
| 462892 | [Stretch][Variable Object][Cable/Bus] Quantity not updated after user uses Stretch command |
| 472011 | [Move][Cable Method] symbol's existing mirrored orientation is not maintained is symbol was mirrored using Mirror Object Command |
| 473174 | Insert Cable: 3D Cables inserted in 3D layout mode with the Millimeters as units the cable is not inserted correctly |
| 473379 | [BOM Manager][Edit][Starting Balloon No] incorrect handling of balloon number assignment for devices without partnumbers |
| 473623 | [BOM Manager] change device's partnumber for device with placed symbol removes part number and balloon values from device associated with placed symbol |
| 473627 | [BOM Manager][Validation][Duplicate balloon number] not always showing all duplicates |
| 473824 | [Load Work Order]It should display default “Activate Work Orders” in the Load Work Order dialog. |
| 474386 | [Insert 3D Objects] Set variables in the Placement Options will not work properly |
| 475723 | [TLS1.2][Backup Project] An error occurs when backup project using only SQL Server TLS 1.2 settings |
| 476000 | [Delete][Field]Installation and Location values not updating after user selects Yes to rename Installation/Location fields |
| 476003 | [Delete][Field] Installation, Location, and Device Tag values disappear from Device Properties after user selects No to not duplicate device ID's |
| 476703 | [Device Properties][Select Device ID] unexpected Device usage chart appears after selecting device ID on drawing |
| 477174 | [PW integration][Project Manager]Check in dialog pops up twice |
| 478191 | [BOM Manager][Submit] Submit Flag not set when BOM is submitted to SAP |
| 478396 | [Chinese Language Package on EN OS][Auto Backup]The projects which name or path contain Chinese characters can’t be auto backup. |
| 478432 | [PW_Configuration Variables] Click PW browse to select the displayed cfg file for ELEC_PARTS_DB_MAPPING_PATH, an error appears |
| 479016 | [BOM Manager][Edit][Starting Balloon No] unable to renumber Nameplate balloon number if Starting Balloon number less than or equal to highest balloon in project |
| 479963 | [BOM Manager][Submit] field or fields not truncated properly |
| 482210 | [Move To Database] incorrect message displayed when one or more pages of project are open |
| 482751 | Update TP feature list in installer as we moved to PP U15. |
| 483197 | [Catalog Manager] The Thumbnail is grayed out with ProjectWise Datasource |
| 483586 | [Reports][BOM_Substation_QTY] missing report records when filtering by WorkOrder, BOM Document, Revision Number |
| 483751 | [Alert Message] An unexpected Alert dialog occurs with multi functions in the new Substation build 10.09.01.07 |
| 488605 | [Performance] There is a memory leak issue in Insert Symbol dialog |
| 488721 | [Display Style] Setting the Display style will crash |
| 488805 | [Update Cable object] The cable level will be changed to PHASE or CABLE_NAKED after update cable object |
| 496389 | [Cable Object] It will change the decimals notation to scientific notation when update cable object |
| 496648 | [Draw Cable] It cannot draw cable properly except the Spline sag algorithm with the MM seed file |
| 499586 | [BOM Manager] add a part from database in BOM Manager dialog, and then insert the object in the drawing by insert symbol by device id, the symbol lost the work order attributes. |
| 500395 | [Reporting] An error occurs when running Text on drawing text on drawing and there is workorder filter in the report “BOM_Substation_Qty”. |
| 502068 | [iModelHub]Cannot publish a project to iModelHub server because of PP U15. |
| 502338 | [Reporting] An error occurs when running the report “Job Costing List – A4” or “Job Costing List – Letter” in the project “CATLETT SUBSTATION TRAINING.Prj” |
| 506556 | [Copy Project][Work Order Manager] Work Order Manager will list duplicate work order in the copied project |
| 511060 | [BOM Manager][Add Spare] Insert Balloon should never cause duplicate balloon numbers on same BOM Document(Insert Spare – Revision Level and Insert Spare – Document Level). |
| 511907 | [BOM Manager] Load lowercase and uppercase BOM Document will report error in BOM Manager |
| 515669 | [Replace/ Update Symbol] When a child symbol is modified and then replaced or updated in Project the connection points for child symbols are changed |
