| Version(s): | All | ||
| Area: | Key-in Commands | ||
| Subarea: | ProStructures Key-in | ||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
| Updated By: | Vyanktesh Nama, Bentley Product Advantage Group |
The data or the geometry of a user shape has been changed in the User Shape Manager. But the shape in the model is still the old one.
Shape references must be reloaded.
Use key in ProStructure Reload References in the Key-in dialog.
Hit Enter in the dialog. All shapes will be updated.
`1``
Perform command PS_RELOAD_REFERENCES
Hit ok in the dialog. All shapes will be updated.
