| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX | ||
| Environment: | Windows 7 64 bit | ||
| Area: | Component | ||
| Subarea: | Graphics | ||
| Original Author: | Rahul Kumar, Bentley Technical Support Group | ||
In OpenPlant Modeler, to place a tap port on Blind flange.
During Modeling in OpenPlant Modeler, placement of Tap port on Blind flange might be tricky and does not allow user to place it on face of flange. Below are the steps to aid modeler to be able to place the Tap port on Blind flange face.
See Similar link for related problem on placement issue:
communities.bentley.com/.../22015.tap-port-connection-on-blind-flange-placement-issue
