| Product(s): | ProSteel |
| Version(s): | All |
| Area: | Shapes/Objects |
| Subarea: | Primitives |
| Original Author | Detlef Hackbarth, Bentley Technical Support Group |
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
In order to create a ProSteel conical pipe draw a simple line or Smartline.
1. Draw a simple line with the basic program.
2. Choose "Conical Pipe" from the "Primitives" ribbon group located at Steel workflow > Home > Primitives.
3. "Identify axis of cone" by selecting the line.
4. Now, enter Lower outer diameter > Lower inner diameter > Upper outer diameter > Upper inner diameter by numerically.
Once you enter all the values correctly then you will see the Conical Pipe.
