| Product(s): | ProSteel |
| Version(s): | All |
| Area: | Steel Shapes/Objects |
| Subarea: | Plates |
| Original Author | Elias Morkos, Bentley Technical Support Group |
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
This is a solution to create Conical Funnels in ProSteel/ProStructures using Bent Plates.
- Create a 180º Arc with the AutoCAD Arc Command then mirror it to form a complete circle.
- Then select the ProSteel Create Plates Button or type on the command line PS_PLATE.
- From the ProSteel Plates/Polyplates dialog box > go to the Arc Plates tab > set the with to the thickness you desire the funnel to be > set the width to the length you need > select the option to Insert a Polyplate by selected Arc.
- Once the Arc is selected you will see the plate inserted > enter the in the Rotation rectangle the angle you need the funnel sides to have then click -Phi. > the plate will take the angle.
- Repeat the procedure for the second Arc.
