| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.440 | ||
| Environment: | Windows 7 64 bit | ||
| Area: | Training | ||
| Subarea: | N\A | ||
| Original Author: | Kestutis Mitkus, Bentley Technical Support Group | ||
This article will explain the procedure of how to create a new custom Joint.
In Weld Value Map Class Select Properties Tab, Copy and Paste similar WELD Property.
Change copied Properties Values, edit Applied Custom Attributes Location to OpenPlant_3D_Supplemental_Modeling.01.04 and save the schema changes.
Use specification with required End condition.
