| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX | ||
| Environment: | Windows 7 64 bit | ||
| Area: | Component | ||
| Subarea: | Graphics | ||
| Original Author: | Kestutis Mitkus, Bentley Technical Support Group | ||
In OpenPlant Modeler, after Section clip placement and projection generation User is willing to have all centerlines visible.
During Modeling in OpenPlant Modeler after Section clip placement, pipelines axes are shown only in the case where the sectional surface intersects the tube. Below are the steps of how to turn on Centerline visibility.
Below is a brief demonstration video with above described steps.
See Similar link for related problem on placement issue:
