| | Applies To | | |
| | Product(s): | OpenPlant Modeler, OpenPlant Isometrics Manager, OpenPlant ModelServer | |
| | Version(s): | 08.11.09.404 | |
| | Environment: | N/A | |
| | Area: | Schema | |
| | Subarea: | | |
| | Original Author: | Justinas Lipnickas, Bentley Technical Support Group | |
After Upgrading to OpenPlant Modeler SS5 Refresh Release 08.11.09.404 users should also update their current schemas to include newly added features in 404 version. There have been some issues with Iso Break points usage on 404, if schemas are not updated, also there could be some not yet reported issues, which can occur if some of required properties are not added into your schemas.
Bellow is the list of all schema changes between OPM 08.11.09.383 and 08.11.09.404 versions.
Schema Changes
Changes done after 08.11.09.383 commercial release:
- OpenPlant_3D.01.04.ecschema.xml:
- Added new property HANDLE_OFFSET to GEARBOX_OPERATOR class
- Added new property PORT_ID to ISOMETRIC_BREAK_POINT class
- Added new property as BEND_RADIUS
- OpenPlant_3D_Supplemental_Imperial_DefaultValues.01.04.ecschema.xml
- Added default property HANDLE_OFFSET to GEARBOX_OPERATOR class
- Changed default value of COMPONENT_SHAPE property for HVAC_RECTANGULAR_TO_ROUND_LATERAL class.
- OpenPlant_3D_Supplemental_Isometrics_Isoextractor.01.04.ecschema.xml
- Query for continuity on taps
- OpenPlant_3D_Supplemental_Metric_DefaultValues.01.04.ecschema.xml
- OpenPlant_3D_Supplemental_MixMetric_DefaultValues.01.04.ecschema.xml
- OpenPlant_3D_Supplemental_Model_Server.01.04.ecschema.xml
- Changed VALVE_OPERATING_DEVICE BACKWARD_QUERY_DEPTH to 1
- MODELSERVER_CLASS_MAP on VALVE
- ISO_SHEET_HAS_DEVICE not marked as DoNotLockSource ( OPMS supplemental schema update for DoNotLock Souce)
- Added 'Plant_Area_Has_Named_Item' relationship
- OpenPlant_3D_Supplemental_Modeling.01.04.ecschema.xml
- Removed duplicate OpenPlant_CustomAttributes definition for OpenPLANT Wave.
- Removed Specification from certain HVAC Component Name
- OpenPlant_3D_Supplemental_ModelingViews.01.04.ecschema.xml
- Updated schemas for changes related to GEARBOX valve operator
- OpenPlant_IsoExtractor_Custom_Attributes.01.00.ecschema.xml
[[Bentley OpenPlant Modeler]]
Comments or Corrections?
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
