| Product(s): | ProSteel |
| Version(s): | All |
| Area: | Steel Shapes/Objects |
| Subarea: | Bolting |
| Original Author | Detlef Hackbarth, Bentley Technical Support Group |
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
You might find the command "Automatic Bolting" not working as expected.
In the Bolting Dialogue tab Bolting set the Tolerances of Gap and Angle to the value of 1:
