| Product(s): | ProSteel |
| Version(s): | All Versions |
| Area: | General |
| Subarea: | N/A |
| Original Author | Johannes Michalowsky, Bentley Technical Support Group |
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
some Elements of the shop drawing are suddenly not visible in the Plot / Preview.
Those Elements are on the Layer Defpoints which is not printable
Select the Elements on the drawing and right click > choose Properties.
Now switch the layer to PS_solid then try to print.
