| Product(s): | ProSteel |
| Version(s): | All Versions |
| Area: | General |
| Subarea: | Manipulation Tools |
| Original Author | Roger Belen, Bentley Technical Support Group |
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
The Prostructures Options is considered as the global settings for standards that you would like to use within a specific model. Some of the examples that you can set in the ProSteel Options are, Text Height and Styles, Part Labels, Layout of the shapes, Levels, etc. You need to do this before you start working on a project. However there are some instances wherein you are in a middle of a job and you would like to make changes in the ProSteel Options Settings and would like to reflect it on your current project. This Wiki will show some examples on how to reflect the changes.
User have inserted a shape and decided to turn the Part Labels ON.
NOTE: There is a MACRO to HIDE/SHOW Part Label. This example is how changes in the ProSteel Options can reflect in the model by doing it manually. You can always use the HIDE/SHOW Part Label command.
User have inserted a shape and decided to change the Text Colour, Height and Style
