| Product(s): | ProSteel 3D Professional | ||
| Version(s): | All | ||
| Area: | ProSteel Utilities | ||
| Subarea: | Search Parts | ||
| Original Author: | Steffen Knoll, Bentley Product Advantage Group | ||
| Updated By: | Vyanktesh Nama, Bentley Product Advantage Group |
How to find all flat steel in a model.
1. Start ProSteel Search Parts.
2. Update / Scan the dialog with the information from the model.
3. If a filter is already set, clear it.
4. Set the filter to shape type=Flat Steel and take over the expression.
5. Set option to Hide other objects.
6. Start searching the model by OK button.
