| | Applies To | | |
| | Product(s): | AutoPLANT Piping | |
| | Version(s): | All | |
| | Environment: | N/A | |
| | Area: | N/A | |
| | Subarea: | N/A | |
| | Original Author: | Derek Cornell, Bentley Technical Support Group | |
The annotation for the spool tag in Isogen only allows up to fifteen characters displayed before it cuts off. This technote shows how to increase that value.
- Open the following file in notepad:
..\program files\bentley\plant v8i\xchg\pcf\opcfhdr.ebs - Find the following line in that script file:
nStat = at_XchgWritelnData(" SPOOL-IDENTIFIER ", "SPOOL", AT_XCHG_STRING, "", 15, 3, "", AT_XCHG_OPTIONAL) - The "15" is the value of the Spool tag length in Isogen. Increase the value to "20".
nStat = at_XchgWritelnData(" SPOOL-IDENTIFIER ", "SPOOL", AT_XCHG_STRING, "", 20, 3, "", AT_XCHG_OPTIONAL) - Save and close the file.
- Restart AutoPLANT. This is very important since the changes will not be recognized until a new session of AutoPLANT is started.
Product TechNotes and FAQs
Plant TechNotes And FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
