| | Applies To | | |
| | Product(s): | AutoPLANT, AutoIsogen | |
| | Version(s): | V8i | |
| | Environment: | N/A | |
| | Area: | Import/Export | |
| | Subarea: | N/A | |
| | Original Author: | Bentley Technical Support Group | |
The annotation format for tag number is different between control valves and Pressure Temperature gauges. This is a solution to format the annotation the same way as other instruments where the tag is split to three levels.
How do I split the tag number annotation to three lines for a Pressue-Temperature gauge in Isogen
- Open the following file in notepad: ..\modules\base\xchg\pcf\DIALOUT.EBS
- Add the following three dim statements
Dim tag As String
Dim separator As Integer
Dim startLoc As Integer - Then add the following code immediately after the first within the if-then statement.
status = at_Component_getString (tag, compID, "TAGNUMBER")
startLoc = 1
Do
separator = Instr (startLoc, tag, "-", 1)
If (separator <> 0) Then
Mid$(tag, separator, 1) = "$"
status = at_Component_putString (tag, compID, "TAGNUMBER")
End If
StartLoc = separator + 1
Loop While (separator <> 0) - Save and close the file.
- Restart AutoPLANT and then regenerate the iso.
Product TechNotes and FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
