| Product(s): | Bentley Substation | ||
| Version(s): | Connect | ||
| Area: | PowerPlatform Support | ||
| Subarea: | N/A |
After opening a project page there is no drawing area, it is just a gray, blank area.
All the Views are toggled off.
After opening the page, look near the bottom of the screen. There should be several small buttons numbered 1 through 8.
If you do not see the view toggle buttons, select Tools > Views > View Groups > Open As Toolbox.
Click the 1 button to turn on View 1.
If the page reverts to having no views enabled when it is reopened, enable View 1 once again then select File > Save Settings.
Do not attempt to close pages by clicking the X button in the upper right of the design area. This closes the view but does not close the DGN file.
The proper ways to close a page include the following:
Keywords: empty, grey, window, does not, cannot open, display
