| Product(s): | AutoPLANT Piping | ||
| Version(s): | 08.06.01.06(2004), 08.09.03.30(XM), 08.11.05.36(V8i) | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
| Original Author: | Richard DeLong, Bentley Technical Support Group | ||
Sometimes, it is desired to suppress the North Arrow in an iso that is being generated from isogen. Typically, users will just delete it after the iso is ran, but there is a way to suppress the iso. The following steps can be used in AutoPLANT 2004, XM, and V8i.
Now the North Arrow should no longer appear in the isos. Run Isogen to test this out.
