| Product(s): | AutoPLANT | ||
| Version(s): | XM 08.09.3.30 | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
| Original Author: | Joey Bertone, Bentley Technical Support Group | ||
When generating an Iso drawing from AutoPLANT Piping model the error "Plotfile-Prefix must have trailing path delimiter" appears in the Export Progress dialoge and an Isogen DWG or DXF is not created.
The "Plotfile-Prefix must have trailing path delimiter" error is caused because the backslash "\" delimiter was dropped from the PLOTFILE-PREFIX path record in the isogen.fls file. To correct the error a backslash "\" needs to be added to the end of the PLOTFILE-PREFIX record.
Use the following steps using the SAMPLE_IMPERIAL project and Final Style as an example to correct the error.
Please note that the project and style folder may change depending on the project and style in use.
