| Product(s): | AutoPLANT AutoISOGEN | ||
| Version(s): | V8, XM, V8i | ||
| Area: | |||
| Subarea: | N/A | ||
| Original Author: | Artiom Jakubovic, Bentley Technical Support Group | ||
There are a few components and module's of components that are not supported for PCF output. These include: Cable Tray module components, Conduit module components, HVAC module components, Flanged Cross Outlet in Ductile module, Diaphragm Valve w/Purge Port in Swagelok module, 5, 6, and 7 Way Valve in Swagelok module, and Valve-O-Let in Base module.
