Fudge Rebar Tool - 2D Rebar Detailing
Fudge Rebar is used to offset the overlapped 2D Rebar by required distance in 2D drawing
The tool can be accessed from Concrete > Drawing Production > 2D Rebar > Fudge Rebar. Please note that these tools can only beused while in 2D drawing models.
This tool also contains sets of methods which helps to simplify and easily arrange the rebars as per your requirement. The following are the examples.
1. Type of Fudge
Single Leg Fudge - This method can be used to fudge the long bars without end conditions.
Whole Bar Fudge This method can be used to fudge long bars having end conditions.
2. Method of Fudging
Dynamics - This method allows the user to move the long bar / long bar group to a required direction and accept the new location using a Data point. The dialog remains opened after applying the fudge and can be used again to apply to other long bar / long bar groups.
Distance - This method allows the user the specify the distance by which the user desired to move the bars and accept by using a Data point. Move the bars to a required direction and accept the location by using a Data point.
Bar Size This method allows the user the specify a Bar Multiplier value by which the user desired to move the bars and accept by using a Data point. Move the bars to a required direction and accept the location by using a Data point.
Rotate - This method allows the user to rotate a bar leg to a specified direction.
See Index
