| Product(s): | Promis.e | ||
| Version(s): | Connect | ||
| Area: | Project Management | ||
| Subarea: | Project Manager |
The Export To DWG tool will create static drawing files in .DWG format in the specified folder.
Bentley Substation users should refer to the [Batch Convert project pages to DWG] article instead.
| Original Author: | Avanti K |
keywords: convert, conversion, batch, AutoCAD, save as
