| 515173 | [Cable/Bus][Placement Options]Custom phase level for cable/bus | |
| 252118 | Radius at cable diagram merges instead of diagonal lines | |
| 494045 | [Copy From Reference File] Add Maintain Options for: Device/Wire Link/Wire Numbers/Terminal Numbers | |
| 522440 | [Wire Diagram][Cable Diagrams] add ability to configure and display cross references for cable symbols | |
| 522615 | [Wire Diagram][Project Options Setting][Device] add Jumper Display setting to control when Installation/Location/Device Tag and Wiring Address values are shown | |
| 521748 | [BOM Manager][Submit][Validation] prevent submission when JSON Deliveryaddress field does not have a value | |
| 586774 | [DB version] Short Term: Add Sub-version for Substation DB version. | |
| 230753 | ODBC connection failure while "Back-Up Project" on cloud based configuration | |
| 540785 | [iModel Hub Connector] Coordinate System not Published | |
| 554138 | [Azure DB]Configuration not saved: no permission | |
| 552877 | [iModelHub]The device IDs are incorrect after publishing the project to iModelHub. | |
| 433228 | Error The Family doesn't exist, or the symbol does not belong to it | |
| 435609 | [Configuration Variables] An unexpected character '\' appears in the end for ELEC_CATALOG_PATH when it's end with an empty space | |
| 519926 | [PW_Software Startup] Remove some variables from Substation.cfg, launch and define correct values and click OK in Configuration Variables, error appears | |
| 519931 | [PW_Software Startup] Define invalid path format for some variables in Substation.cfg, launch and click OK in Configuration Variables, error appears | |
| 519937 | [PW_Software Startup] Set invalid value for some variables in Substation.cfg, launch to set correct value and click OK in Configuration Variables, error appears | |
| 520823 | [Software Startup] Fail to define ELEC_CATALOG_PATH in Configuration Variables when remove or define wrong in Substation.cfg | |
| 520827 | [PW_Software Startup]It displays strangely for some Variables in Configuration Variables when define invalid path format in Substation.cfg | |
| 520837 | [PW_Software Startup] Define invalid path for some variables in Substation.cfg, there's no action when click OK in Configuration Variables | |
| 504558 | [WorkSpace WorkSet] It displays WorkSpace WorkSet for selected projects,not the opened project | |
| 511728 | [Insert Substation Object] When user is inserting Substation Objects of Linear or Repeating Type the symbols gets Conductor level automatically assigned | |
| 521294 | [Device Properties][Copy 3D Objects] Right click menu command Device Properties of device tag shows wrong device tag with copied object | |
| 517961 | [Move][Cable Method] It cannot maintain the object's rotation on the horizontal cable | |
| 517977 | [Move Options][Copy Options] Method filed is not writable in the Move Options and Copy Options' dialogs | |
| 518560 | [Insert Linear and Repeating object] It should enable the Length variable in the Substation Object Settings dialog when insert Linear and repeating object by name | |
| 392409 | [BOM Manager] It cannot edit the Nameplate attributes in the BOM Manager dialog if there are the different lowercase and uppercase defination in the BOM Manager Settings | |
| 479985 | [3D object-Symbol Text] It cannot deal with the copied objects' Symbol Text properly | |
| 480071 | [PW integration] It hasn't updated the page status icon mark after back up project in Project Manager | |
| 483100 | [Cable/Bus] It will generate one bend line when draw cable from high point to one low point | |
| 488839 | [Update Cable Object] The ParamValue will show long decimals character in the Cable/Bus Object Settings dialog | |
| 514236 | [Insert Linear] It cannot enable the Length variable in the Placement Option dialog for the first time when insert Linear object for the first time | |
| 514459 | [Insert Linear Object] it cannot define the start and end point of the linear object after place a single object for the first time | |
| 514470 | [Insert Linear object and repeating object] It should generate the linear object correctly when lenght value for Null or Blank | |
| 515046 | [Move][Cable Method] Move object with cable method should maintain Horizontal mirrored object's rotation | |
| 517471 | [Draw Cable object]Sometimes it just draws the cable center line without cable graphic on the drawing | |
| 560190 | [BOM Manager] It should correct the spelling of the word "seprate" in the Add Device dialog | |
| 553059 | [Installer] Failed to install the new Substation build 10.10.00.06 | |
| 571955 | [Symbol Creation] It will crash when execute the right click command on 3D objects during modification symbol | |
| 572278 | [Insert Cable/Bus] Sometimes it cannot show whole Placement Options dialog during draw cable | |
| 499475 | [Insert Linear Object] After draw cable, insert linear object will execute the cable command | |
| 500225 | [Update Substation Object] It cannot update object's Angle in Substation Object Settings dialog | |
| 519787 | [ProjectWise Integration][Project Manager][Copy Project] unable to copy project when ProjectWise User Setting 'Can Delete' Folder is disabled | |
| 480296 | [Data Manager] It should update the project icon in the Data Manager dialog | |
| 463302 | [3D Feature-Update icon] There are some dialogs' icons should be updated | |
| 487085 | [Overwrite Cable] When Overwrite cable is selected after a cable symbol is edited the entire cable route is replaced with a small cable with size of the cable seen in symbol creation | |
| 580387 | [Cable Diagram]The output merge value is not correct by default. | |
| 585852 | [Wiring Diagram Settings]The Installation/Location display is not correct if setting them display as If different than page. | |
| 392578 | [BOM Manager]It cannot popup the warning info if modify the balloon number out the range when Group by Balloon. | |
| 453031 | [BOM Manager]The installation and location of the same device are not correct after switching from Device to Balloon in the BOM Manager dialog. | |
| 473902 | [BOM Manager]Device Tag sort order is not correct after copying the devices from one revision to other revision. | |
| 482598 | [Run Reports]The revision number cannot sort by number correctly in Run Reports->Filter dialog. | |
| 522420 | [Wire Diagram][Terminal Symbol] terminal number attributes missing and not populating with correct values | |
| 522426 | [Wire Diagram][Terminal Symbol] wire number attributes not populating on wiring diagram symbol | |
| 441109 | [Create Symbol]Right clicking a symbol without device tag->clicking Place Symbol again, it popups error dialog. | |
| 463456 | [Modify Component]Select symbols with part number which are not existed in the part database->Modify Component->Part number, it popups error dialog after clicking the Save&Exit button in the select Part number dialog. | |
| 574107 | [Copy from reference file]The device tag of Terminal or symbol with family is not correct if not maintain the Device tag in the Paste options dialog. | |
| 520836 | [Balloon][BOM Manager]Modify a balloon with more than two balloon no values inserted by BOM Manager, the result is not correct. | |
| 484680 | [Search]Change the part number, in the Search dialog, the original and latest part number both display in the Search dialog. | |
| 521519 | [PW][Project Manager]Restore/Update a user’s project, the pages cannot list in the detail tab after finishing the restoring. | |
| 535366 | [PGE's Environment] Unhandled error on startup | |
| 508059 | [PW Explorer Plug in] Cannot update project properties from PW Explorer only in the PG&E environment | |
| 526223 | [Installer] SQL Database connection issues occur when Microsoft SQL Server 2014 Express (BENTLEYECAD) option is deselected during installation | |
| 521716 | [BOM Manager][Submit] Comments JSON field not always populated with Internal Comments value from BOM Manager | |
| 454585 | [Submit BOM] Two Submit BOM dialogs are popped up when the Submit BOM button is clicked twice | |
| 358811 | [ProjectWise][TitleBlock] Cannot import title block information when modifying the existing title block in PW integration | |
| 478403 | [Auto Backup] There is no AutoBackup.log file in the local Target Path YYMMDD folder. | |
| 477184 | [PW integration][PG&E Environment]Configuration Variables dialog gets crash during validation | |
| 517929 | [Device Usage][SUBID] placing schematic mode symbol with family does not link with existing Devices/Symbols in other modes | |
| 533376 | [Martian] [Translation] The “CheckedOut By” is not translated in the project Manager dialog | |
| 519769 | [BOM Manager][Edit][Starting Balloon No] incorrect handling of balloon number assignment when some devices have different balloon value for same partnumbers | |
| 519771 | [BOM Manager][Nameplate] Nameplate Devices missing from Nameplate view after Nameplate Part Number is assigned to existing Device & assigned Nameplate Part Number is removed from Devices | |
| 520214 | [BOM Manager][Validation][Nameplate Before & After Material] validation results not correct based on BOM Tree selection | |
| 520240 | [Work Order Manager][Column Chooser] unable to open Column Chooser | |
| 541386 | [PW]It popups Unhandled Error and “Orange X” in Project Manager if the checkouted ProjectOptions.XML is deleted from dms folder. | |
| 541429 | [PW]Cannot see "Checkedout By" information for opened page for specific projects | |
| 551734 | [PW Integration]Noticed performance issue when select Project in Tree view | |
| 583935 | [BOM Manager] Clicking the root node in BOM Tree after load data By BOM Document reports error in PG&E “Midway Substation” project. | |
| 384524 | Insert symbol on wire with wire number / label prompts message to delete wire number | |
| 449937 | [Catalog Manager] delete option should be disabled for Catalogs on right click menu in Details Dialog Panel | |
| 460133 | [Software Startup] Configuration Variables not showing variable values which exist in Substation.cfg when one or more variables are missing | |
| 462426 | Network WorkSpace: Upon restart of Promis.e it is not pointing to the default project folder as per the details in the configuration variables | |
| 474736 | [Diagonal Wire] When drawing diagonal wire type between to wire potential no EDC dialog pops up | |
| 474786 | [Wire Link] When placing wire link pair on wires with different potential the user doesn't get EDC check dialog | |
| 480177 | [Data Manager] Replace All command cannot replace all texts in the Data Manager | |
| 504400 | [Page Open] The user is getting Error message when they select No while opening a page which is read only due to the reason that its already in user by another user | |
| 517607 | [Cable Cross Reference] The Wiring diagram details for cable cross reference are changed as the equipment's sides are swapped when V8i project is restored in CONNECT | |
| 517799 | [Part Number Settings] When V8 Project is restored in Custom user workspace in CONNECT Part Number text settings are not updated | |
| 517845 | [Insert Macro] Insert Macro crashing while placing some of the macros from user custom catalog | |
| 520513 | Sorting of pages in Project publisher is not numerical | |
| 526618 | [New Page][Modify Page] embedded raster image missing from Title Block | |
| 547665 | [Move PLC Symbol] When PLC parent symbol is moved Cross Reference text position changes | |
| 559683 | [Cross Reference] When Device Cross Reference is turned on the device id gets visible for the cross reference | |
| 569777 | [Terminal Manager] Terminal is not loading in Terminal Manager | |
| 570837 | [Wire Type] When Wire Type is changed to Diagonal type is not maintained when Promis.e is restarted | |
