| BUG/ENHANCEMENT | DESCRIPTION |
| 384524 | Insert symbol on wire with wire number / label prompts message to delete wire number |
| 449937 | [Catalog Manager] delete option should be disabled for Catalogs on right click menu in Details Dialog Panel |
| 460133 | [Software Startup] Configuration Variables not showing variable values which exist in Substation.cfg when one or more variables are missing |
| 462426 | Network WorkSpace: Upon restart of Promis.e it is not pointing to the default project folder as per the details in the configuration variables |
| 474736 | [Diagonal Wire] When drawing diagonal wire type between to wire potential no EDC dialog pops up |
| 474786 | [Wire Link] When placing wire link pair on wires with different potential the user doesn't get EDC check dialog |
| 480177 | [Data Manager] Replace All command cannot replace all texts in the Data Manager |
| 504400 | [Page Open] The user is getting Error message when they select No while opening a page which is read only due to the reason that its already in user by another user |
| 517607 | [Cable Cross Reference] The Wiring diagram details for cable cross reference are changed as the equipment's sides are swapped when V8i project is restored in CONNECT |
| 517799 | [Part Number Settings] When V8 Project is restored in Custom user workspace in CONNECT Part Number text settings are not updated |
| 517845 | [Insert Macro] Insert Macro crashing while placing some of the macros from user custom catalog |
| 520513 | Sorting of pages in Project publisher is not numerical |
| 526618 | [New Page][Modify Page] embedded raster image missing from Title Block |
| 547665 | [Move PLC Symbol] When PLC parent symbol is moved Cross Reference text position changes |
| 559683 | [Cross Reference] When Device Cross Reference is turned on the device id gets visible for the cross reference |
| 569777 | [Terminal Manager] Terminal is not loading in Terminal Manager |
| 570837 | [Wire Type] When Wire Type is changed to Diagonal type is not maintained when Promis.e is restarted |
| 252118 | Radius at cable diagram merges instead of diagonal lines |
| 494045 | [Copy From Reference File] Add Maintain Options for: Device/Wire Link/Wire Numbers/Terminal Numbers |
| 522440 | [Wire Diagram][Cable Diagrams] add ability to configure and display cross references for cable symbols |
| 522615 | [Wire Diagram][Project Options Setting][Device] add Jumper Display setting to control when Installation/Location/Device Tag and Wiring Address values are shown |
| 521748 | [BOM Manager][Submit][Validation] prevent submission when JSON Deliveryaddress field does not have a value |
| 586774 | [DB version] Short Term: Add Sub-version for Promis.e DB version. |
| 230753 | ODBC connection failure while "Back-Up Project" on cloud based configuration |
| 540785 | [iModel Hub Connector] Coordinate System not Published |
| 554138 | [Azure DB]Configuration not saved: no permission |
| 552877 | [iModelHub]The device IDs are incorrect after publishing the project to iModelHub. |
| 433228 | Error The Family doesn't exist, or the symbol does not belong to it |
| 435609 | [Configuration Variables] An unexpected character '\' appears in the end for ELEC_CATALOG_PATH when it's end with an empty space |
| 519926 | [PW_Software Startup] Remove some variables from Substation.cfg, launch and define correct values and click OK in Configuration Variables, error appears |
| 519931 | [PW_Software Startup] Define invalid path format for some variables in Substation.cfg, launch and click OK in Configuration Variables, error appears |
| 519937 | [PW_Software Startup] Set invalid value for some variables in Substation.cfg, launch to set correct value and click OK in Configuration Variables, error appears |
| 520823 | [Software Startup] Fail to define ELEC_CATALOG_PATH in Configuration Variables when remove or define wrong in Substation.cfg |
| 520827 | [PW_Software Startup]It displays strangely for some Variables in Configuration Variables when define invalid path format in Substation.cfg |
| 520837 | [PW_Software Startup] Define invalid path for some variables in Substation.cfg, there's no action when click OK in Configuration Variables |
| 504558 | [WorkSpace WorkSet] It displays WorkSpace WorkSet for selected projects,not the opened project |
| 392409 | [BOM Manager] It cannot edit the Nameplate attributes in the BOM Manager dialog if there are the different lowercase and uppercase defination in the BOM Manager Settings |
| 480071 | [PW integration] It hasn't updated the page status icon mark after back up project in Project Manager |
| 560190 | [BOM Manager] It should correct the spelling of the word "seprate" in the Add Device dialog |
| 553059 | [Installer] Failed to install the new Substation build 10.10.00.06 |
| 519787 | [ProjectWise Integration][Project Manager][Copy Project] unable to copy project when ProjectWise User Setting 'Can Delete' Folder is disabled |
| 480296 | [Data Manager] It should update the project icon in the Data Manager dialog |
| 580387 | [Cable Diagram]The output merge value is not correct by default. |
| 585852 | [Wiring Diagram Settings]The Installation/Location display is not correct if setting them display as If different than page. |
| 392578 | [BOM Manager]It cannot popup the warning info if modify the balloon number out the range when Group by Balloon. |
| 453031 | [BOM Manager]The installation and location of the same device are not correct after switching from Device to Balloon in the BOM Manager dialog. |
| 473902 | [BOM Manager]Device Tag sort order is not correct after copying the devices from one revision to other revision. |
| 482598 | [Run Reports]The revision number cannot sort by number correctly in Run Reports->Filter dialog. |
| 522420 | [Wire Diagram][Terminal Symbol] terminal number attributes missing and not populating with correct values |
| 522426 | [Wire Diagram][Terminal Symbol] wire number attributes not populating on wiring diagram symbol |
| 441109 | [Create Symbol]Right clicking a symbol without device tag->clicking Place Symbol again, it popups error dialog. |
| 463456 | [Modify Component]Select symbols with part number which are not existed in the part database->Modify Component->Part number, it popups error dialog after clicking the Save&Exit button in the select Part number dialog. |
| 574107 | [Copy from reference file]The device tag of Terminal or symbol with family is not correct if not maintain the Device tag in the Paste options dialog. |
| 520836 | [Balloon][BOM Manager]Modify a balloon with more than two balloon no values inserted by BOM Manager, the result is not correct. |
| 484680 | [Search]Change the part number, in the Search dialog, the original and latest part number both display in the Search dialog. |
| 521519 | [PW][Project Manager]Restore/Update a user’s project, the pages cannot list in the detail tab after finishing the restoring. |
| 521716 | [BOM Manager][Submit] Comments JSON field not always populated with Internal Comments value from BOM Manager |
| 454585 | [Submit BOM] Two Submit BOM dialogs are popped up when the Submit BOM button is clicked twice |
| 358811 | [ProjectWise][TitleBlock] Cannot import title block information when modifying the existing title block in PW integration |
| 478403 | [Auto Backup] There is no AutoBackup.log file in the local Target Path YYMMDD folder. |
| 477184 | [PW integration][Environment]Configuration Variables dialog gets crash during validation |
| 517929 | [Device Usage][SUBID] placing schematic mode symbol with family does not link with existing Devices/Symbols in other modes |
| 533376 | [Martian] [Translation] The “CheckedOut By” is not translated in the project Manager dialog |
| 519769 | [BOM Manager][Edit][Starting Balloon No] incorrect handling of balloon number assignment when some devices have different balloon value for same partnumbers |
| 519771 | [BOM Manager][Nameplate] Nameplate Devices missing from Nameplate view after Nameplate Part Number is assigned to existing Device & assigned Nameplate Part Number is removed from Devices |
| 520214 | [BOM Manager][Validation][Nameplate Before & After Material] validation results not correct based on BOM Tree selection |
| 520240 | [Work Order Manager][Column Chooser] unable to open Column Chooser |
| 541386 | [PW]It popups Unhandled Error and “Orange X” in Project Manager if the checkouted ProjectOptions.XML is deleted from dms folder. |
| 541429 | [PW]Cannot see "Checkedout By" information for opened page for specific projects |
| 551734 | [PW Integration]Noticed performance issue when select Project in Tree view |
| 583935 | [BOM Manager] Clicking the root node in BOM Tree after load data By BOM Document reports error in project. |
