| Product(s): | Promis.e CONNECT | ||
| Version(s): | 10.00.XX.XX to 10.05.XX.XX | ||
| Area: | Installation_Configuration | ||
| Subarea: | N/A |
The purpose of this document is to indicate the compatibility of various software with Promis.e. It is not intended to describe compatibility of the various software with each other. For example, certain versions of SQL Server may not be compatible with certain operating systems. Always check the documentation of the various software involved.
An archive of the compatibility chart for promis.e 2007 through promis.e V8i SS3 can be found [[5648|here]].
For Promis.e V8i version Compatibility Chart click here.
| Promis.e Version | CONNECT Update 5 (10.05.00.38) | CONNECT Update 4 (10.04.00.22) | CONNECT Update 3 (10.03.00.35) | CONNECT Update 2 (10.02.00.29) | CONNECT Update 1 (10.01.00.07) | CONNECT (10.00.00.49) | ||
| Operating System | ||||||||
| Windows 10 (64-bit) | Yes | Yes | Yes | Yes | Yes | Yes | ||
| Windows 8.1 (64-bit) | Yes | Yes | Yes | Yes | Yes | Yes | ||
| Windows 7 (64-bit) | No | Yes | Yes | Yes | Yes | Yes | ||
| Windows Server 2019 (64-bit) | Yes | No | No | No | No | No | ||
| Windows Server 2016 (64-bit) | Yes | Yes | Yes | |||||
| Windows Server 2012 (64-bit) | Yes | Yes | Yes | Yes | Yes | Yes | ||
| Database Software | ||||||||
| SQL Server 2019 (Inclusing Express) | Yes* | Yes* | Yes* | Yes* | Yes* | Yes* | ||
| SQL Server 2017 (Inclusing Express) | Yes* | Yes* | Yes* | Yes* | Yes* | Yes* | ||
| SQL Server 2016 (Including Express) | Yes* | Yes* | Yes* | Yes* | Yes* | Yes* | ||
| SQL Server 2014 (Including Express) | Yes* | Yes* | Yes* | Yes* | Yes* | Yes* | ||
| SQL Server 2012 (Including Express) | Yes* | Yes* | ||||||
| ProjectWise Integration | ||||||||
| ProjectWise CONNECT 10.00.03.329 | Yes | |||||||
| ProjectWise CONNECT 10.00.03.280 | Yes | Yes | ||||||
| ProjectWise CONNECT 10.00.03.271 | Yes | Yes | Yes | |||||
| ProjectWise CONNECT 10.00.03.262 | Yes | Yes | Yes | Yes | Yes | |||
| ProjectWise CONNECT 10.00.03.167 | Yes | Yes | Yes | Yes | Yes | Yes | ||
| ProjectWise CONNECT 10.00.03.140 | No | No | No | No | No | No | ||
| ProjectWise CONNECT 10.00.02.320 | No | No | No | No | No | No | ||
| ProjectWise CONNECT 10.00.02.265 | No | No | No | No | No | No | ||
Refer the Promis.e CONNECT Readme for details. For Online Promis.e Readme click here.
[[Project Database Version]]
[[Updating and Upgrading promis.e]]
[[How to download the promis.e software]]
[[Moving From promis.e for AutoCAD to promis.e Standalone]]
[[Compatibility Chart - Bentley Substation]]
