| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.564 | ||
| Environment: | Windows 7 (64 bit) | ||
| Area: | Component | ||
| Subarea: | Graphics | ||
| Original Author: | Rahul Kumar, Bentley Technical Support Group | ||
In OpenPlant Modeler, to assign Shop or Field Value for Multiple Components.
User requirement was to assign Shop or Field value while placing components in model. Also it has been required to assign values for existing components in the model, whose values are missing. Below steps has been described to achieve above requirements in one way. However there could be other way to model the components based on Shop or Field value i.e. assigning the value through spec and get the desired data. User may refer this in other wiki links discussed later on it.
For New Items:
For Existing items:
