| Product(s): | OpenPlant Modeler/OpenPlant Isometrics Manager | ||
| Version(s): | 08.11.09.XXX | ||
| Environment: | Windows 7 (64 bit) | ||
| Area: | Component | ||
| Subarea: | Graphics | ||
| Original Author: | Rahul Kumar, Bentley Technical Support Group | ||
In OpenPlant Modeler Placement of tap ports on blind flange locates incorrectly. Below description will resolve the problem.
During placement of tap ports on Blind flange, user was unable to locate the tap port on face of flange. It was getting placed at its mating point of another flange. see image below.
Further processing the iso sheet and generating the Isometrics produces the error as shown in below image:
ERROR[0]: Tap point on component can not be associated with component segment
Also see log content generated from isometrics Manager
If above problem still persist, then please create a Service Request and contact Bentley Product Advantage group along with the list of all relevant details to get in depth analysis and for possible solution or workarounds.
