| Product(s): | ProConcrete |
| Environment: | N/A |
| Area: | Drawing Production |
| Subarea: | 2D Rebar Modification |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
This LCOL variable in the Display.sys file allows to set up the color and line weight of the label and delimiter lines while detailing concrete and rebar models in ProStructures.
1) Open the Display.sys file that is located at C:\ProgramData\Bentley\ProStructures CONNECT Edition\Configuration\WorkSpaces\*Your WorkSpace*\Standards\ProStructures\Rebar\Detailing\Metric
NOTE – The above mentioned path is the default location and may defer if you have installed the application at another folder path
2) Search for the LCOL variable (which would be located at line # 1397) and set the value to 1, 1
3) Save and close this file
4) Now start the ProStructures application (restart if the application was open while making the above changes)
5) Place a new callout tool in the 3D model and you will observe that the label and delimiter lines are created in accordance to the new parameters set in the LCOL variable
In this way, by setting up the value of the LCOL variable in the Display.sys file, one can control the display settings of the label and delimiter lines for the 2D rebars in the drawing model
